Please see attached file. Why is the program giving a message "area required - Failed"? What exactly does this mean? Please advise.
DennisStudy 5 MS.sfa
Can you please attach the screenshot of the error message? Also specify the version of STAAD Foundation Advanced you are using. I tested the same in my machine and found that, you have created some regions with no specifications. I deleted all such regions and now the model runs fine for me.
I'm using version 8.2.0.31 (I don't have access to the latest version). Screenshots 1 shows some of the "Warnings". Screenshot 2 shows "Instability". Screenshot 3 shows "Failed" reinforcement design. I only see 1 region in my file and don't see the drop down option in your screenshot (please see my screenshot4). How do I delete the other regions?
The attachments dint come through. Can you attach them once again?
Please see attached. What's causing the instability? Thanks
Follow up on this. Please advise
