how to model double beam with a single beam
Dear sir,
Kindly advise how we can attach two beams with a single beam as shown in the attached drawings section 5a in staad pro.. the primary beam size is UB1016*305 AND SECONDARY TWO BEAMS ARE UC 203*203*46KG. staad file is also attached . Kindly advise this method is correct or not?
Thank you.
PDFPDF
4152.Structure1.std
