I am working on a clod formed structure and using IS801 in Staad Version 22010039.
As in older version it is very easy to create any section by modification of section data base to perform analysis through IS801.
But it take lot of time to modify the section database in latest version STAAD, because it need more information in database related to section properties. so i need to know can there is any way to analysis built up section using IS801.
or if there is any specific calculator is available for calculating the all property as required in STAAD 22010039.
Looking forward your help.
Thanks and Regards,
Hi Vikash Pathak,
In the latest version of STAAD.Pro CE (22.01.00.39), IS801 has been revised and all the section properties as per IS811 is implemented in the Section Database. If you need to add any section apart from the ones that are provided, you will have to calculate all the section properties and then add it to the Section Database. There isn't any specific calculator for the calculation of the section property.
Aritra
