Hi, I tried to create a new model at the physical modeler, but when a tried to return to analitycal, it shown this error
Any suggestion to fix this error.
Best Regards
Which STAAD.Pro version are you using? Could you please attach that STAAD.Pro model (.std and .stdp files)?
The vertions it's 21.00.02.43
2018-08-22 CONCRETE CULVER - PHYSICAL.STD
Try to upgrade to the most recent STAAD.Pro CE - version 22.01.00.39 and see if that helps.
The Problems were solved with the instalation of the vertion STAAD.Pro Advanced CONNECT Edition - Version 22.00.00.15.
Thanks for the helps
