Hi. I am used to STAAD.ProV8i for more than 10 years. It's my first time to use STAAD Pro.Connect, and I find it really difficult. If I could just go back to V8i, I would choose to.
With so many icons now in different location, to have the frequently used icons be put on topmost part of my screen would be a very big help. But the problem is even on how to do that, I could not find it.
I've tried to search in the internet for a solution:communities.bentley.com/.../customizing-the-interface-in-staad-pro-connect-edition
Option 1 : Customizing the Quick Access ToolbarThere is now a Quick Access Toolbar at the top of the ribbon menu which may be used to add the frequently used icons to the toolbar. Click on the down arrow as shown next. The menu will expand. Click on the More Commands option as seen below.----->>> When I do this, there's no More Commands in the dropdown.
Option 2 : Customizing the Quick Commands Pop up menuWhile inside the Whole Structure window press the Spacebar on the keyboard to bring up the Quick Commands menu as shown next. Click on the lower right corner to customize the quick command. ----->>> When I do this, nothing shows up.
Please help me in here because I feel I got really slow in doing my project, spending time to find always the location of each icons.
I can customize the Quick Commands Pop up menu but the next day it disappears. Again I need to arrange the more frequent tools. I am using STAAD.Pro CONNECT Edition - Version 22.12.00.142 and talking about the Option 2: Customizing the Quick Commands Pop up menu.
Hi, i am using STAAD.Pro 2023. Every time i customize quick command menu ( Opens by pressing Space bar) i get the same issue. I loose all m,y preferences as soon as I restart the program. Need a solution for it as it takes longer to model. I had no problem in last version.
I followed the same procedure mentioned by Shreyanka in this post, RE: CUSTOMIZE QUICK ACCESS TOOLBAR and is working fine. Follow the same process in case you need to add or delete or arrange any tool.
