FLOOR LOAD
Dear sir,
In attached stad file. I am applying the dead load 2kn/m2 as floor load.
1.somewhere I am attaching two secondary beams with primary beams with the same node.is this load distributed all over the area same as 2kn/m2 or where I am having two members there it is double? is my way is correct?
2. beam no 10  connection with column the value of moment z is coming 2108kn.m. is this value I should consider while designing the connection of this beam with column or only I should consider shear force which will compress the column ? as the beam is sitting on the column with bottom flange. I have given also My, Mz release to the top node of the column. Kindly give me your opinion.
Thank you
podium canopy7.std
