I am new to staad and my analytical model is completed. But whenever I try to launch staad RCDC to design beams or columns I get the message "Beam/columns are missing". Any clues on what's going on ?
Please attach that STAAD.Pro model.
Modestas, the problem does happens regardless of the model. Even with the samples projects that comes with the software.
Please let us know which version of Staad RCDC is installed in your machine. Meanwhile will try with the sample models if we face the same error.
I am using Staad Advanced Concrete Design 08.00.00.16 along with Staad.pro Advanced Connect edition V. 22.00.00.15. The model is here attached
UK-8 Concrete Design for a Space Frame.STD
Hi Chris,
I have checked your staad model in our latest version of Staad Pro Adv CE 22.00.01.39 along with Staad RCDC 08.00.01.23, i didn't get any message of Beams missing in any of the element(Column or Beam). Would request you to upgrade your software to the latest version and check if the issue still persist.
Answer Verified By: Abhisek M
