Can you add a concentrated moment to a plate in STAAD Connect?
I am new Civil Engineering graduate that is working on the design of electrical substations. I am currently modelling a structure simple structure where I have two horizontal beams that are connected to each other by a plate. On top of the plate are transformers. When my structure is subjected to lateral loads such as wind, the equipment will transfer the horizontal force and a moment to my beam through the plate. I was able to add a vertical concentrated load onto the center of my plate, but was unable to add a concentrated moment. Is there a way to implement this? I also believe that I can add a horizontal concentrated force on my plate correct? Is there also a way I can view the stresses on my plate?
Thank you!
Parents Reply Children
