The current version that gets operated is the V8i and needs to get that into the Connect Edition.
What is the procedure that must be done to migrate from the older version to the new connect.
can anyone help on this matter.
Step one is to accept that you are going from a productive & mostly working version of Microstation to a version that slows people down and still does not work properly.
--Robert
We have a number of online documents that you may find helpful. Would you mind telling us a bit more about the context that you are operating in?
Do you have an existing shared workspace for V8i, which product(s) are you using, how many user are involved?
Marc
currently using STAAD.Pro and around 4 users
Any migration questions regarding STAAD.Proand related products is best done in our dedicated STAAD/RAM forum.
The process to upgrade to STAAD.Pro CE is quite straight forward. Just uninstall any STAAD.Pro V8i from your machine, then download STAAD.Pro CONNECT Edition version 22.01.00.39 from here: https://softwaredownloads.bentley.com/en/. Then run the downloaded installer and proceed with the installation steps. Once the installation is finished, sign in to the CONNECTION Client and run STAAD.Pro to see if it is running fine.
