i cant import any etabs files into rcdc. am receiving error saying unable to read analysis file. how do i solve this?
Can you please mention the version numbers of the software(s) you are using?
CSI_ETABS_2016_v16.2.1_Build_1727_x64 and RCDC_V8i_v07.00.02.09_x64
Can you please download the access run time driver and install the same in your machine and check whether you face the same issue.
https://bentley.sharefile.com/d-s565245a862c47e19
Answer Verified By: femi ajibade
can you please share the link of access run time driver again as it is expired now ?
Please find the link below for your reference.
https://bentley.sharefile.com/d-sac75ace48a84603a
