Hello all,
I`m trying to retrieve LX,LY,LZ Design parameters by Openstaad.
But the Design.GetMemberDesignParameters function is not working.
I dont know how the LPDISPATCH works.
Please tell me how I can use the function of GetMemberDesignParameters to get information about steel design parameters like LX,LY,LZ.
Openstaad HELP in Connect Edition
long OSDesignUI::GetMemberDesignParameters ( long nBriefRef, long nMemberNo, LPDISPATCH pDesignParams)
Returns the design parameters for specified member in specified design brief.
Parameters
[in] nBriefRef The Design Brief reference ID.
[in] nMemberNo Member number ID.
[out] pDesignParams Design parameters:[Name, Value, Unit, Description, Default].
VBA Syntax
' Get design parameters defined in Design Brief #1 for member #2.Dim RetVal As long = OSDesignUI.GetMemberDesignParameters(1, 2, &pDesignParams)
I tried like this but not working..
Sub GETRESULT()
Dim OS As ObjectSet OS = GetObject(, "StaadPro.OPenSTAAD")
Dim pDesignParams As Object 'I tried this as string or double but not worked either
RetVal = OS.Design.GetMemberDesignParameters(1, 2, pDesignParams)
msgbox RetVal
end sub
Hi Jeong,
Sorry for the delay. Please find code snippet on the usage of the above API.
'#Reference {EDA9FA7F-EFC9-4264-9513-39CF6E72604D}#1.0#0#C:\SPro CE\STAAD\StaadPro.dll#OpenSTAADUI#OpenSTAADUIOption Explicit
Sub Main Dim objOpenStaad As OpenSTAAD Dim stdFile As String
Set objOpenStaad = GetObject(,"StaadPro.OpenSTAAD") objOpenStaad.GetSTAADFile stdFile, "TRUE" If stdFile="" Then MsgBox"Bad" Set objOpenStaad = Nothing Exit Sub End If
Dim params As IOSMemberSteelDgnParams
Set params = CreateObject("StaadPro.MembSteelDgnParams")
objOpenStaad.Design.GetMemberDesignParameters 0, 2, params
'MsgBox ("The Member Number is " & params.MemberNumber) -------------> this does not work MsgBox ("Total Parameter Count is " & params.Count)
' you can loop through all the params, here only accessing the 2nd index of the array MsgBox ("The Value of Parameter " & params.Name(2) & " is " & params.Value(2)) MsgBox"Macro Ending" Set objOpenStaad = Nothing End Sub
We are in the process to redesign our manual, till then feel free to get in touch if you face any issues.
Rudra Lahiri
Senior Principal Software Engineer, Structural
I have the same question and am still unable to get this API to work. Specifically I am trying to extract the Member FYLD. Rudra, you mention
"Dim params As IOSMemberSteelDgnParams"
but that does not seem to be a valid type. Should I be using Variant?
Rudra Lahiri said:Dim objOpenStaad As OpenSTAAD
Huh? It should be "Dim objOpenStaad As Object". Params should also be dimensioned as an object. Until I made these changes your code snippet would not work.
Also, what's the deal with the first argument in the GetMemberDesignParameters function? The manual says that's the design brief reference ID. What the . . .? I'm only familiar with the term "design brief" back when you had that silly GUI steel design do-dad. It's not even in the latest version of STAAD.Pro.
And lastly, I'm glad to hear you are redesigning the manual. It is literally the worst I have ever seen.
Hi Joseph,
The above declaration will work if you include "Staadpro.dll" as a Reference to your project.
You can do this by launching the 'ScriptEditor' in administrator mode and select the above dll by browsing to the STAAD installation folder. Once added, the reference object will be available in the list if you launch the 'ScriptEditor' in normal mode. By including the DLL as reference, the intellisense of the object will be enabled. That means by putting a '.' after the object, you will get the list of its functions.
If you are unable to add the reference, the way @Tank mentioned will work.
Hope this helps.
Hi Tank,
Thanks for helping out Joseph.
For your query, the first argument is the index of the PARAMETER/Design block count in the STD file. If there is only one PARAMETER block, then it will be '1' and subsequent blocks will be in serial increment like 2,3.. If you send '0' then it will iterate for the member number in all the blocks and return that of the first one.
And yes, we are working on the format of the API manual.
By the way, we have redesigned the Backup/Restore feature in latest Update 2 build. Have you tried it? Will be happy to hear your feedback. Will be adding a comparison tool in the next update.
