I am designing a floor slab for the below mentioned view of the building. In the plan view the center part of the portion is to be left empty and the remaining area should be covered by slabs. In how many ways can i design a slab to account for both the loading and the stiffness of the slab. Also how will the loading of the slab changes in those cases.
Hello sir. Based on this your answer, I have a question.
Beams that are splited during plate meshing, do I need to merge them again to become one?
Because analyzing it as splited makes the beam to be series of beams with equal spans corresponding to the mesh segments. Thanks
No, you do not need to merge it. If you merge the beams, the connectivity between the beams and the plates will not be correct.
Thanks Modestas.
