Hi.... We are designing a RCC structure in which column are inclined/tapered (V shaped). When the staad model is imported in to RCDC for designing, it does not recognize the tapered/inclined columns and "columns are missing"is reflected? Please guide in this regard.
RCDC can not take care of tapered section. But if you want to design of any other shape that can be done within RCDC.
Thanks. Can we introduce a vertical column (in between tapered columns) in staad pro and while designing in RCDC , ignore vertical column ?. It is showing tapered columns. But i am not sure how accurate the results will be .......
I am not getting your question correctly.
Can you please upload the files here?
porch.STDPls find attached file.
