Can you please let me know which version of RCDC is installed in your machine. Please share the source file to check the issue further from our end.
I encountered the same problem when trying to click auto design for my columns. Who can help me please?
I have also same problem
Kindly share the file with us to scrutinize the whole issue. meanwhile let us know which version are you encountering this error.If the older version is installed then would recommend you to check in our latest version.
You can download the latest version from our Bentley website. Follow the link below:
https://select.bentley.com/FulfillmentCenter/en/Search/Product/LTEyMzE5NjgyOTdfNC4wLjIuMA#
I have also the same problem. Rcdc v. 8 pro connect
