I have designed a steel structure in Staad pro, No errors are found but in output file some members are getting failed. I dont have any ideas in passing those members. If I change section of those members other members are getting failed. please sort me out from this and also how to optimize the structure.
Thank you.
STAAD SPACE START JOB INFORMATION ENGINEER DATE 06-Sep-19 END JOB INFORMATION INPUT WIDTH 79 UNIT METER KN JOINT COORDINATES 1 0 0 0; 2 8 0 0; 3 0 0 6; 4 8 0 6; 5 0 4 0; 6 4 4 0; 7 8 4 0; 8 0 4 3; 9 8 4 3; 10 0 4 6; 11 4 4 6; 12 8 4 6; 13 0 8 0; 14 4 8 0; 15 8 8 0; 16 0 8 3; 17 8 8 3; 18 0 8 6; 19 4 8 6; 20 8 8 6; 21 0 12 0; 22 2.67 12 0; 23 4 12 0; 24 5.33 12 0; 25 8 12 0; 26 0 12 2.35; 27 2.67 12 2.35; 28 5.33 12 2.35; 29 8 12 2.35; 30 0 12 3; 31 8 12 3; 32 0 12 3.65; 33 2.67 12 3.65; 34 5.33 12 3.65; 35 8 12 3.65; 36 0 12 6; 37 2.67 12 6; 38 4 12 6; 39 5.33 12 6; 40 8 12 6; 41 0 15 0; 42 3.35 15 0; 43 4 15 0; 44 4.65 15 0; 45 5.65 15 0; 46 8 15 0; 47 0 15 2; 48 3.35 15 2; 49 5.65 15 2; 50 8 15 2; 51 0 15 4; 52 3.35 15 4; 53 5.65 15 4; 54 8 15 4; 55 0 15 6; 56 3.35 15 6; 57 4 15 6; 58 4.65 15 6; 59 5.65 15 6; 60 8 15 6; 61 4 18 -1.5; 62 0 18 0; 63 1.33333 18 0; 64 2.66667 18 0; 65 4 18 0; 66 5.33333 18 0; 67 6.66666 18 0; 68 8 18 0; 69 0 18 3; 70 1.33333 18 3; 71 2.66667 18 3; 72 4 18 3; 73 5.33333 18 3; 74 6.66666 18 3; 75 8 18 3; 76 0 18 6; 77 1.33333 18 6; 78 2.66667 18 6; 79 4 18 6; 80 5.33333 18 6; 81 6.66666 18 6; 82 8 18 6; 83 0.0951034 18.0309 0; 84 0.0951034 18.0309 3; 85 0.0951034 18.0309 6; 86 7.80696 18.0627 0; 87 7.80696 18.0627 3; 88 7.80696 18.0627 6; 89 2 18.65 0; 90 6 18.65 0; 91 2 18.65 3; 92 6 18.65 3; 93 2 18.65 6; 94 6 18.65 6; 95 3.80696 19.2373 0; 96 3.80696 19.2373 3; 97 3.80696 19.2373 6; 98 4.0951 19.2691 0; 99 4.0951 19.2691 3; 100 4.0951 19.2691 6; 101 4 19.3 0; 102 4 19.3 3; 103 4 19.3 6; MEMBER INCIDENCES 1 1 5; 2 6 1; 3 2 6; 4 7 2; 5 1 8; 6 9 2; 7 8 3; 8 4 9; 9 3 10; 10 3 11; 11 11 4; 12 12 4; 13 5 6; 14 6 7; 15 5 8; 16 7 9; 17 8 10; 18 9 12; 19 10 11; 20 11 12; 21 5 13; 22 14 5; 23 7 14; 24 15 7; 25 5 16; 26 17 7; 27 16 10; 28 12 17; 29 10 18; 30 10 19; 31 19 12; 32 20 12; 33 13 14; 34 14 15; 35 13 16; 36 15 17; 37 16 18; 38 17 20; 39 18 19; 40 19 20; 41 13 21; 42 23 13; 43 15 23; 44 25 15; 45 13 30; 46 31 15; 47 30 18; 48 20 31; 49 18 36; 50 18 38; 51 38 20; 52 40 20; 53 21 22; 54 22 23; 55 23 24; 56 24 25; 57 21 26; 58 22 27; 59 24 28; 60 25 29; 61 26 27; 62 27 28; 63 28 29; 64 26 30; 65 29 31; 66 30 32; 67 31 35; 68 32 33; 69 33 34; 70 34 35; 71 32 36; 72 33 37; 73 34 39; 74 35 40; 75 36 37; 76 37 38; 77 38 39; 78 39 40; 79 21 41; 80 21 43; 81 43 25; 82 46 25; 83 41 36; 84 55 21; 85 36 55; 86 36 57; 87 57 40; 88 60 40; 89 41 42; 90 42 43; 91 43 44; 92 44 45; 93 45 46; 94 41 47; 95 42 48; 96 45 49; 97 46 50; 98 47 48; 99 49 50; 100 47 51; 101 48 52; 102 44 58; 103 49 53; 104 50 54; 105 51 52; 106 53 54; 107 51 55; 108 52 56; 109 53 59; 110 54 60; 111 55 56; 112 56 57; 113 57 58; 114 58 59; 115 59 60; 116 41 62; 117 41 65; 118 65 46; 119 68 46; 120 62 55; 121 41 76; 122 60 68; 123 82 46; 124 55 76; 125 82 60; 126 65 61; 127 62 63; 128 63 64; 129 64 65; 130 65 66; 131 66 67; 132 67 68; 133 62 69; 134 63 70; 135 64 71; 136 72 65; 137 66 73; 138 67 74; 139 68 75; 140 69 70; 141 70 71; 142 71 72; 143 72 73; 144 73 74; 145 74 75; 146 69 76; 147 70 77; 148 71 78; 149 79 72; 150 73 80; 151 74 81; 152 75 82; 153 76 77; 154 77 78; 155 78 79; 156 79 80; 157 80 81; 158 81 82; 159 62 83; 160 69 84; 161 76 85; 162 83 84; 163 84 85; 164 86 68; 165 87 75; 166 88 82; 167 86 87; 168 87 88; 169 89 63; 170 64 89; 171 66 90; 172 90 67; 173 91 70; 174 71 91; 175 73 92; 176 92 74; 177 93 77; 178 78 93; 179 80 94; 180 94 81; 181 83 89; 182 84 91; 183 85 93; 184 90 86; 185 92 87; 186 94 88; 187 101 64; 188 101 66; 189 89 91; 190 90 92; 191 102 71; 192 102 73; 193 91 93; 194 92 94; 195 103 78; 196 103 80; 197 89 95; 198 91 96; 199 93 97; 200 98 90; 201 99 92; 202 100 94; 203 95 96; 204 96 97; 205 95 101; 206 96 102; 207 97 103; 208 98 99; 209 99 100; 210 101 98; 211 102 99; 212 103 100; 213 101 102; 214 102 103; DEFINE MATERIAL START ISOTROPIC STEEL E 2.05e+008 POISSON 0.3 DENSITY 76.8195 ALPHA 1.2e-005 DAMP 0.03 TYPE STEEL STRENGTH FY 253200 FU 407800 RY 1.5 RT 1.2 END DEFINE MATERIAL MEMBER PROPERTY INDIAN 61 TO 63 68 TO 70 95 96 101 TO 103 108 109 116 119 124 125 TABLE ST ISMB200 169 TO 180 187 188 191 192 195 196 TABLE LD ISA55X55X6 2 3 5 TO 8 10 11 13 TO 20 22 23 25 TO 28 30 31 33 TO 40 42 43 45 TO 48 50 - 51 80 81 83 84 86 87 117 118 120 TO 123 TABLE LD ISA75X75X6 127 TO 135 137 TO 148 150 TO 161 164 TO 166 181 TO 186 197 TO 202 205 TO 207 - 210 TO 214 TABLE LD ISA90X90X6 58 59 72 73 98 99 105 106 162 163 167 168 189 190 193 194 203 204 208 - 209 TABLE ST ISMC100 1 4 9 12 21 24 29 32 41 44 49 52 79 82 85 88 126 136 149 TABLE ST ISMB300 53 TO 57 60 64 TO 67 71 74 TO 78 89 TO 94 97 100 104 107 110 TO 114 - 115 TABLE ST ISMB250 CONSTANTS MATERIAL STEEL ALL SUPPORTS 1 TO 4 FIXED DEFINE WIND LOAD TYPE 1 WIND 1 <! STAAD PRO GENERATED DATA DO NOT MODIFY !!! ASCE-7-2010:PARAMS 85.000 KMPH 0 1 1 0 0.000 FT 0.000 FT 0.000 FT 1 - 1 19.300 M 8.000 M 6.000 M 2.000 0.010 0 - 0 0 0 0 0.867 1.000 1.000 0.850 0 - 0 0 0 0.861 0.800 -0.550 !> END GENERATED DATA BLOCK INT 0.253723 0.253723 0.261237 0.26775 0.273531 0.278752 0.283527 0.287938 - 0.292045 0.295895 0.299522 0.302956 0.306219 0.309331 0.312307 HEIG 0 4.572 - 5.70492 6.83785 7.97077 9.10369 10.2366 11.3695 12.5025 13.6354 - 14.7683 15.9012 17.0341 18.1671 19.3 EXP 1 JOINT 1 TO 60 62 64 TO 66 68 76 78 TO 80 82 83 85 86 88 TO 90 - 93 TO 95 97 98 100 101 103 LOAD 1 LOADTYPE Dead TITLE DL SELFWEIGHT Y -1 JOINT LOAD 62 68 69 75 76 82 89 TO 103 FY -5 LOAD 2 LOADTYPE Live REDUCIBLE TITLE LL MEMBER LOAD 126 133 139 146 152 159 TO 161 164 TO 166 181 TO 186 189 190 193 194 - 197 TO 214 UNI GY -5 LOAD 3 LOADTYPE Wind TITLE WL X WIND LOAD X 1 TYPE 1 YR 12 19.3 LOAD 4 LOADTYPE Wind TITLE WL Z WIND LOAD Z 1 TYPE 1 YR 12 19.3 LOAD COMB 6 COMBINATION LOAD CASE 6 1 1.0 2 1.0 LOAD COMB 7 COMBINATION LOAD CASE 7 1 1.5 2 1.5 PERFORM ANALYSIS PRINT ALL PARAMETER 1 CODE INDIAN CHECK CODE ALL PARAMETER 2 CODE INDIAN STEEL MEMBER TAKE OFF ALL PARAMETER 3 CODE INDIAN SELECT ALL PARAMETER 4 CODE INDIAN SELECT OPTIMIZED PARAMETER 5 CODE INDIAN STEEL TAKE OFF ALL PARAMETER 6 CODE INDIAN FYLD 250000 ALL FINISH
There were lot of redundant parameter commands in the designIf you use SELECT OPTIMIZED you should follow that up with a PERFORM ANALYSIS and CHECK CODE. Please refer to the technical reference for details.You should also enter FIXED GROUP to group similar memberYou need to use design parameters ( unbraced lengths, Unbraced lengths for compression flanges etc.) to control the design. Check out the list of design parameters specific to the Indian design code.You may need to run multiple design cycles to get all members to pass.You should design for only load combinations
I have attached a modified file which you may use as a guideline. However first you need to add the design parameters and group commands.
Also please ensure that you are using the latest version of STAAD.Pro CONNECT Edition ( 22.02.00.26)
4300.Structure1.STD
can you provide me technical reference details and also user manual for staad pro steel structures.
All manuals can be found in STAAD.Pro Help by clicking on the Help icon on the right top corner of STAAD.Pro.
