HI,
Download and install Access run time driver from the below link and check if you are facing the same issue.
https://bentley.sharefile.com/d-s923acce3cf34d389
Please can you resend the link, mine is unable to read analysis data linked from Etabsv18
You may refer the below link.
https://communities.bentley.com/products/ram-staad/m/structural_analysis_and_design_gallery/274125
its not that the program is giving problem in database, the problem is that it gives me "License for the design code can not be found" and "Unable to read analysis data" any time am linking an analysis result from Etabsv18 with RCDC V8.0 and same goes for v7 and v6.3. Please what can i do, i urgently need to generate the footing and also detail the column and beam of a proposed building.
Hello ,
Please click on the link for our reference .
https://bentley.sharefile.com/d-sac75ace48a84603a
thanks so much shinde, when am done installing the access runtime i will give you an update concerning it if it works
