STAAD CE V22.02.00 - "Combinations Methods" Setting - More information?
I just saw the news for the new release, and wondering if there is more information on what the setting "Combination Methods" does?
Is this only for the physical modeler for generating automatic combinations? If I made a manual Primary Load Case that uses the REPEAT command for other Primary Load cases (or Reference Load Cases), does this setting impact this combination? Or, is this only for the COMBINATION load definition that would treat the load cases defined in the COMBINATION case as REPEAT loads?
Thanks in advance!
Parents Reply Children
