Hi.
I created an ISM file from my Revit model. I was able to open the ISM in RAM Structural system. All beams, columns, slabs, etc. have been modelled, however, I am missing loads. I input a number of line loads and point loads in the Revit model via Analyze, Loads (under Analytical Model. These were gravity loads. I expeced to find these loads in the Modeller module of RAM, however, they are not there. Any insights would be helpful.
RAM SS can export loads to ISM, but not import them.
Thanks for the quick response. is there a way to quickly apply line loads in RAM Modeller. I have a large number of line loads and it can be very time consuming to add construction grids to define exact load locations.
Here is a trick to use a background dxf that might help, but with line loads I worry about cases where the line loads are just slightly off of a beam. https://communities.bentley.com/products/ram-staad/w/structural_analysis_and_design__wiki/10314/ram-ss---using-dxf-as-a-reference-layout
