7357.Research 2.std
I designed a structure for our undergraduate research but i keep messing up with errors and warnings such as
-zero stiffness
-instability at joints
-member not supported
is my designed structure just not designed well or i can't combine steel design on top of a concrete design?
thank you for answering.
Use TRUSS specification for the web members only, but not for the top and bottom chords to avoid the instabilities.Assign the CHECK CODE command to the steel members, but not to the concrete members to avoid the "member not supported" errors.
Answer Verified By: Rom Jason Gacusana
It worked, thank you so much sir! Kinda new to staad and relying on youtube and this community to slowly learn to use staad.
