After complete running the file, the software start reading the design results and suddenly STAAD disappear. opening the same file again is impossible as it freeze at reading results until it disappear. I am using Windows 10 X64. Agaaaaaaaaaaaaaaaaaaaaaaaaain why you release untested update every time.
Please attach that STAAD.Pro model and let us know the exact STAAD.Pro version being used.
The latest version, as i mentioned How many latest version has been issued a few days ago !!!! , and no matter what file i use all of them ended with same result even STAAD Examples.
It creates all the output files after running but can not read results and freeze until disappear. re-opening STAAD file will stop in reading results until same end as before. Will not able to open the file again unless i delete all output generated files and keep the .std file alone. I tried to open the file and save it in this updated version and then run it again but same end. I need a solution.
Please try clean installation, the steps to do are described here:https://communities.bentley.com/products/ram-staad/w/structural_analysis_and_design__wiki/37038/perform-clean-installation-of-staad-pro-connect-edition
Unfortunately, it doesn't help. I uninstalled this untested update 2 and reinstalled previous update 1 until you solve the issue.
