1 way shear effective depth calculation
I have an existing two-way slab that I am trying to analyze. At locations of negative bending, the effective depth for one way shear calculations is much smaller than I'm calculating it to be by hand.
Based on the value that the audit is showing, it looks like it is using the reinforcement at the bottom as tension reinforcement and calculating the effective depth as the distance from the bottom of the slab to the centroid of the bottom reinforcement rather than the tension reinforcement at the top face. I've set the CS shear effective depth calc to "Maximum Effective Depth", but I am still having this issue.
How can I fix this?
Parents Reply Children
