I recently updated staad pro version 22.02.00.26 and since then I'm facing problems in the section database. Whenever I open the section database to select a steel section from the Indian database, It displays the message "there are no profiles for this table in this database. To add profiles to a database use 'section DB manager' from the menu Tools>Section Database". I tried to open the section database from the specification menu but unable to add profiles. Please help! (I have also attached the image for your reference.)
Hello Dwivedi A K,
Please try running STAAD.Pro with administrative rights. To do that right click on the STAAD.Pro icon and click on "Run as administrator".
If still the problem persists, please uninstall and reinstall STAAD.Pro.
