During Base plate design for axial compression load after providing A2 i.e support with pedestal longitudinal dimension 36 in and transverse dimension 24 in,A2 should be 36X24=864 sqin,But it is showing ,
A2 = ((B/N)*Ncs)*Ncs
=((19/33)*36)*36
=746.18 sqin
Can not find this equation,A2 = ((B/N)*Ncs)*Ncs in the reference DG1, sec 3.1.1.
Can you help with that......
Its Ram connection standalone v12.Design Code AISC-360-05- LRFD..DOCX .mail.google.com/.../0
Can you try the latest version (13.01.00.76)? I see different consultations for the axial bearing check, pinned base plate, AISC 360-05 w/ pedestal.
Thanks, next time just send the .rcnx file and I won't overlook anything like that.
I matched your results now. Below is a highlight from the design guide and my sketch to explain.
Base Plate.cnxCan you check this file ? As per your opinion this file is showing other thing as A2.
In this design A2 should be (15/43)*48 but from where 51.6 value comes ??
Base Plate.cnx
If total area considered as provided for A2 should not greater than 48X18=864 sqin but it becomes 928.8 sqin. what is the reason for that. .cnx file is attached at that comment by Nazmul Haq...
Gentle Reminder...
It looks like the program is assuming that the length of the pedestal will be enough to maintain the aspect ratio of the BP when the width of the pedestal is reached (i.e. 43/15 * 18 = 51.6"), but in this case it should be limited to 48". Increasing the pedestal width to 20" cause A2 to come back in line. I'll report the error.
