Hi
I am trying to create a Custom Base Plate Connection into Ram Connection module in STAAD.Pro CE.
I able to create a custom connection (see imagen) but when I trie to select the custom connection it has not shown as avaliable connection.
The basic steps are outlined below.
When you define a base plate, you have to check the "Optimizable" option. Because all the Smart connection templates require this value to be TRUE, otherwise it will not show I the list.
Hello, I am not able to create a base plate, under Structural Type I only have two options, FRAME and TRUSS no Base Plate, how can I fix this problem?.
Another question, Is there a way I can add base plate templates into the STAAD Pro Connect edition to work with the Connection Design module?
The Base Plate connection is one of the connection types of Frames:
Yes, you can create a Base Plate template in the Connection Database by adding and new table and then new item to it.
Thank you
