Hi
I am trying to create a Custom Base Plate Connection into Ram Connection module in STAAD.Pro CE.
I able to create a custom connection (see imagen) but when I trie to select the custom connection it has not shown as avaliable connection.
Thank you
Apologies for reviving this old thread, just want to know if there's a workaround to add Base Plate as Basic connection? Every time I assign my template, RAM connection optimizes it (because of being a Smart Connection) thereby changing my default base plate size so it's a bit tedious since I need to readjust it to what I want and I'm doing this for a lot of different columns. Hope you can answer, thank you sir.
