Problem with the tool "RESULT ALONG LINE" after update V22.02
Comparing the solicitations obtained from the Result along line command, before and after installing the update from the V22 update 1 version to the update 2 version, the results are different. With the previous version, I calculated plausible values by estimating the shear stresses in the plane. Now with the new update, using the same cutting line and updated software I get null values that are not realistic, of course. What is it due?
