RAM Elements 2D analysis Instability in Rx because of release conditions
When I use RAM Elements for a 2D analysis such as a beam or column, it says I have a local instability for Node 1 at DOF RX.  If I fix the node for RX, the warning goes away.  I have a couple questions regarding the boundary conditions.
1. Is RX torsion in this case?
2. In this case, since I only have 1 member, does the member hinge conditions do anything?
Parents Reply Children
