After running Frame Analysis in a model with steel frames and shear walls and rigid diaphragm, I am unable to access the diaphragm forces report. Is there a step by step method for accessing diaphragm forces at each level for shear walls?
This only applies for a semi-rigid diaphragm.
Got it. Thanks!
