Good day,
In the process of revising Steel Framing model with STAAD Pro Connect Edition, I used the User Defined Property.
Although there is no mulfunctional things, Unity check or Deflection check(with DFF parameters) cannot be performed.
Please kindly notice that what is the problem with reviewing the attachment.7522.STAAD.stdSection.zip
Best regard
Instead of Prismatic, you should use a General section type for a custom section to design it as per EN 1993-1-1:2005 code.
Answer Verified By: Lee Jong Won 이종원
