i have designed the following truss by partial moment release and found out that the purlins are failing.
kindly help me out!
do i need to give any other parameter other than given in the staad file.
0250.Done by partial moment .99.std
Dear User,
I have run your file in my system and could not find any failed member. I am using 22.02.00.26 version. If you are using any old version please upgrade to the latest one.
Sir, im using the latest version. the property assinged by me to purlin is 48mm diameter pipe. the software is suggesting me to use 88mm diameter pipe. my question to you is,
1]Am i designing the purlin in a proper way? 2]there are many warnings coming up
You have not assigned any additional parameters. So, it is designing the structure considering default values. Please check if it is okay with you as I am not aware of the practical aspects of your structure.
You may refer the link for the warnings.
https://communities.bentley.com/products/ram-staad/w/structural_analysis_and_design__wiki/30240/warnings-in-is800-2007
