Hello Sir,
When i am going to apply wind load on water tank than what happend it is apply on half portion of tank as you can see in the attched screenshot below.
so my question is how can be apply wind on cylindrical as well as conical portion of tank. Kindly give response ASAP.
If your question is why the load is not getting generated on the tank ( modeled using a mesh of plates), the following wiki has the answer
https://communities.bentley.com/products/ram-staad/w/structural_analysis_and_design__wiki/33376/applying-wind-loading-on-plates
THANKYOU SIR.
IF WE ASSIGN BEAM AS A INACTIVE MEMBER.
