I'm using Ram connections in STAAD V8i. Ratio does not display and has warning status
Hello user,
Please upgrade to the latest version of CONNECT Edition and check if the issue still persist.Regards,
Aritra
now using Staad Pro V22. it says
status - not designed. I suppose this is the reason why ratio is not displaying. What should I do?
I think you are dealing with Baseplate connection. If that is the case, then you may find solution from the below link. Please let me know if this helps.
https://communities.bentley.com/products/ram-staad/w/structural_analysis_and_design__wiki/22494/the-solution-was-not-found-for-load-case-error-base-plate-design
It worked! thank you so much.
