FEM
MY QUESTION IS WHEN WE ARE GOING TO DESIGN WATER TANK OR ANY STRUCTURE IN WHICH WE ARE USING PLATE ELEMENT THAN WHENEVER WE GOING TO INCREASE PLATE THICKNESS THAN MOMEMT ALSO EXCEEDED THAN HOW CAN BE GO FOR THE DESIGN OF TANK WALL BECAUSE IF YOU ARE GOING TO REQUIRED THICKNESS CHECK IF IT IS NOT SATISFIED THAN YOU INCREASES THICKNESS BUT MOMEMT ALSO INCREASES THAN AGAIN WE INCREASES THAN AGAIN MOMENT INCREASES. SO PLEASE EXPLAIN ME WHY THIS HAPPEN AND HOW CAN BE PROCEED FURTHER WITH THIS PROBLEM.
