Hello there,
I wonder if there is a way to adjust the block size in Staad Pro Editor. When I use the Collapse/Expand command, the editor closes/expands the block which is not the size we're looking for.
Wenqing
Wenqing: The collapse and expansion are done on the command blocks representing a set of commands. When you choose to expand, the software displays the entire set of commands within that block and similarly when you minimize, the entire set of commands within that block gets minimized. The block size depends on the commands contained within the block. I am not sure if I understood your requirement on controlling the size of the block. Can you please explain the requirement in a little more detail and provide screenshots if possible.
I think the issue is due to the commented lines in your editor file. If you can upload the .std file here, I could delved deep inti your issue.
