For this file the computer locks up after analysis. Analysis takes about 40 seconds and then as it is trying to read results it freezes.
I can open analysis file in staad editor and do not see the problem.
Other more complex files in different folders work fine.
It works under previous version, I just updated to 22020026M19115 SHIP LOADER (+15 DEG).STDM19115 SHIP LOADER (+15 DEG).ANL
This is a known issue in this version. We are looking for a solution. Meanwhile you can refer the below link for a workaround.
https://communities.bentley.com/products/ram-staad/w/structural_analysis_and_design__wiki/43823/staad-pro-crashes-after-aisc-360-16-design-when-tapered-and-non-tapered-members-are-used-in-a-single-design-parameter-block
Answer Verified By: Mike Farmer
Thanks - for nwo I just rolled it back to previous release
