Hello Everybody,
I have modeled a frame with tapered sections (Warehouse) using Eurocode3. when i analyzed the model the design member table is not comming out in the out put file. and when i go to steel member design all numbers coming in the report is zero. I attached the model here.
Can anybody help me in this please !!!Eurocode 3 model.std
Any Help please !! its really urgent !!
Eurocode EC3 does not support design of tapered sections.
what is the suggestion regarding this problem? any newer versions suppots the tapered steel design?
As a workaround, you may split a member into many short and various depth members and design each part separately.
