I'm trying to design concrete columns and getting the following error message in RCDC: Index was outside the bounds of the array. Can someone tell me why I'm getting this error message and how can I proceed?
What application and version are you using so that your question can be moved to the proper forum?
Tamicca SellarsMicroStation Product Manager
I'm using RCDC Advanced Concrete Design V8.0.0. Trying to run a file from STAAD Pro CONNECT Edition V22
I have the same problem, please help me, I need iit rcdc ASAP. I have deadlines in 3 days.
If your problem is file specific, then send it over. Also let us know the exact versions you are using, codes, and other relevant factors. Secure File Upload
Hi I am having same problem in RCDC latest version. I have etabs file, which I convert to .mdb (Access file) and imported that to RCDC version 10. For columns it is fine, but for beams, I have same problem. Can you please assist me? Thanks
