Entering Atypical composite decks
I am in the process of modeling a new building and given the long spans required, we are using an atypical composite deck catalog, using 6.125" of Lightweight 6" flutes.  However i am at loss as how to enter these deck properties, since all the standard choices in RAM are in the 1.5" to 3" range.  Is there a way to input custom deck properties as one of the deck choices?  I've found the RAMDECKS.DCK file with the standard Vulcraft and other deck composite systems (C:/ProgramData/Bentley/Engineering/RAM Structural System/Tables).  However opening the file shows a table where I'm able to infer what some values (flute depth, and spacing) are but not others.  Is there a guide that can tell me what the other values are, or if there is a less hacky way to input atypical deck configurations?
Thank-you in advance.
Parents Reply Children
