Does Ram connection consider shear value for Base plate design ?
Hello Andrew, for anchoring to concrete RAM Connection is based on ACI 318 Appendix D and now Chapter 17 where the shear and tension interaction is done under ACI 17.8. Therefore, RAM Connection is not checking the shear and tension according to AISC 360-16 Sec J3.7. If this is something you usually do, we can log an enhancement and provide an option to perform this check for AISC base plates.
This is something that I typically do. It would be very beneficial if RAM Connection was able to do this also.
Hello Andrew, let us add this enhancement to the backlog and try to include it for Q3-Q4 2023
