Steel Column Bracing Error
I have a column that RAM won't design due to the following error (it is sloped and unbraced at a level). The issue is, the column IS braced at the levels the slope changes (Level 1 and Level 2), and even says so in the View/Update menu. What does T in Splice mean? There is only a mezzanine floor for which this column is unbraced, and that happens to be in the middle of the slope. Is there a way to fix this accurately so that RAM can give me a column design?
