Section properties not accurate
I am designing a steel frame and it has a member L3x3x3/8. The value of S and Z should be same for both minor and major axis. However STAAD Pro uses different values. Additionally, these values are not accurate with the AISC steel manual Table 1-7.
I am using STAAD.Pro CONNECT Edition - Version 22.02.00.26.
