LIMCON
I am using LIMCON to design standard connections with Chinese sections. We have put in a custom database with custom grades, however these will not carry over into the connection design. It will allow me to select the grade (345), but when I press OK, the grade reverts back to 250. Is there anyway to fix this or some reason it may not be working?
Thank you
  • What design code are you using with these custom shapes? Can you send your file? Note, we are replacing Limcon with Ram Connection, and it includes Chinese shapes, materials, and codes.
  • Hi Seth,
    I am using the Australian design code AS4100. I have been uploading the txt file below as an asc file which then gets converted to a lib file in LIMCON.
       8   1
    Covalent Library
     4  1.0  1.0  1.0  1.0
    $ Compile Library from HatchTools.
    $ All data in convert in metric is library data in inches...
    D   1 'Hot-rolled H sections with a Medium flange width to GB/T 11263'
    S   1  2 HM194X150X6X9 Q345B   0   0   3.9760E+03 0 0 8.6220E+04 2.5850E+07 5.0660E+06 8.0632E+01 3.5695E+01 2.6650E+05 6.7540E+04 3.1200E+01 1.9400E+02 1.5000E+02 9.0000E+00 6.0000E+00 0 0.000 2.9620E+05 1.0280E+05 4.3320E+10 2
    S   1  2 HM244X175X7X11 Q345B   0   0   5.6240E+03 0 0 1.8190E+05 5.8670E+07 9.8320E+06 1.0214E+02 4.1812E+01 4.8090E+05 1.1240E+05 4.4100E+01 2.4400E+02 1.7500E+02 1.1000E+01 7.0000E+00 0 0.000 5.3480E+05 1.7120E+05 1.3340E+11 2
    D   2 'Hot-rolled H sections with a Narrow flange width to GB/T 11263'
    S   2  2 HN175X90X5X8 Q345B   0   0   2.3210E+03 0 0 3.7680E+04 1.1720E+07 9.7370E+05 7.1060E+01 2.0482E+01 1.3400E+05 2.1640E+04 1.8200E+01 1.7500E+02 9.0000E+01 8.0000E+00 5.0000E+00 0 0.000 1.5180E+05 3.3390E+04 6.7770E+09 2
    S   2  2 HN200X100X5.5X8 Q345B   0   0   2.7570E+03 0 0 4.4780E+04 1.7610E+07 1.3360E+06 7.9921E+01 2.2013E+01 1.7610E+05 2.6720E+04 2.1700E+01 2.0000E+02 1.0000E+02 8.0000E+00 5.5000E+00 0 0.000 2.0020E+05 4.1390E+04 1.2290E+10 2
    S   2  2 HN250X125X6X9 Q345B   0   0   3.7870E+03 0 0 7.8100E+04 3.8930E+07 2.9340E+06 1.0139E+02 2.7834E+01 3.1140E+05 4.6940E+04 2.9700E+01 2.5000E+02 1.2500E+02 9.0000E+00 6.0000E+00 0 0.000 3.5190E+05 7.2400E+04 4.2540E+10 2
    S   2  2 HN300X150X6.5X9 Q345B   0   0   4.7530E+03 0 0 9.9540E+04 6.9330E+07 5.0690E+06 1.2077E+02 3.2657E+01 4.6220E+05 6.7590E+04 3.7300E+01 3.0000E+02 1.5000E+02 9.0000E+00 6.5000E+00 0 0.000 5.2210E+05 1.0420E+05 1.0720E+11 2
    S   2  2 HN350X175X7X11 Q345B   0   0   6.3660E+03 0 0 1.9400E+05 1.3120E+08 9.8350E+06 1.4356E+02 3.9306E+01 7.4990E+05 1.1240E+05 5.0000E+01 3.5000E+02 1.7500E+02 1.1000E+01 7.0000E+00 0 0.000 8.4080E+05 1.7250E+05 2.8230E+11 2
    S   2  2 HN400X200X8X13 Q345B   0   0   8.4120E+03 0 0 3.5900E+05 2.2960E+08 1.7350E+07 1.6521E+02 4.5415E+01 1.1480E+06 1.7350E+05 6.6000E+01 4.0000E+02 2.0000E+02 1.3000E+01 8.0000E+00 0 0.000 1.2860E+06 2.6600E+05 6.4900E+11 2
    S   2  2 HN446X199X8X12 Q345B   0   0   8.4950E+03 0 0 3.0330E+05 2.7510E+08 1.5780E+07 1.7995E+02 4.3099E+01 1.2330E+06 1.5860E+05 6.6700E+01 4.4600E+02 1.9900E+02 1.2000E+01 8.0000E+00 0 0.000 1.3930E+06 2.4440E+05 7.4220E+11 2
    S   2  2 HN450X200X9X14 Q345B   0   0   9.7410E+03 0 0 4.7180E+05 3.2260E+08 1.8690E+07 1.8198E+02 4.3803E+01 1.4340E+06 1.8690E+05 7.6500E+01 4.5000E+02 2.0000E+02 1.4000E+01 9.0000E+00 0 0.000 1.6210E+06 2.8850E+05 8.8710E+11 2
    S   2  2 HN500X200X10X16 Q345B   0   0   1.1420E+04 0 0 7.0750E+05 4.6040E+08 2.1370E+07 2.0079E+02 4.3258E+01 1.8410E+06 2.1370E+05 8.9600E+01 5.0000E+02 2.0000E+02 1.6000E+01 1.0000E+01 0 0.000 2.0960E+06 3.3170E+05 1.2490E+12 2
    S   2  2 HN600X200X11X17 Q345B   0   0   1.3520E+04 0 0 9.1370E+05 7.4420E+08 2.2730E+07 2.3462E+02 4.1003E+01 2.4810E+06 2.2730E+05 1.0600E+02 6.0000E+02 2.0000E+02 1.7000E+01 1.1000E+01 0 0.000 2.8630E+06 3.5710E+05 1.9260E+12 2
    S   2  2 HN700X300X13X24 Q345B   0   0   2.3550E+04 0 0 3.2600E+06 1.9460E+09 1.0810E+08 2.8746E+02 6.7751E+01 5.5600E+06 7.2080E+05 1.8500E+02 7.0000E+02 3.0000E+02 2.4000E+01 1.3000E+01 0 0.000 6.2490E+06 1.1080E+06 1.2340E+13 2
    S   2  2 HN800X300X14X26 Q345B   0   0   2.6740E+04 0 0 4.2230E+06 2.8260E+09 1.1720E+08 3.2509E+02 6.6204E+01 7.0640E+06 7.8110E+05 2.1000E+02 8.0000E+02 3.0000E+02 2.6000E+01 1.4000E+01 0 0.000 7.9950E+06 1.2070E+06 1.7520E+13 2
    S   2  2 HN900X300X16X28 Q345B   0   0   3.0980E+04 0 0 5.5810E+06 3.9960E+09 1.2630E+08 3.5915E+02 6.3850E+01 8.8810E+06 8.4190E+05 2.4300E+02 9.0000E+02 3.0000E+02 2.8000E+01 1.6000E+01 0 0.000 1.0170E+07 1.3140E+06 2.3950E+13 2
    D   3 'Hot-rolled H sections with a Wide flange width to GB/T 11263'
    S   3  2 HW150X150X7X10 Q345B   0   0   4.0550E+03 0 0 1.1600E+05 1.6010E+07 5.6290E+06 6.2835E+01 3.7258E+01 2.1340E+05 7.5050E+04 3.1900E+01 1.5000E+02 1.5000E+02 1.0000E+01 7.0000E+00 0 0.000 2.3960E+05 1.1410E+05 2.7560E+10 2
    S   3  2 HW175X175X7.5X11 Q345B   0   0   5.1430E+03 0 0 1.7830E+05 2.8160E+07 9.8310E+06 7.3996E+01 4.3721E+01 3.2190E+05 1.1240E+05 4.0300E+01 1.7500E+02 1.7500E+02 1.1000E+01 7.5000E+00 0 0.000 3.5960E+05 1.7060E+05 6.6070E+10 2
    S   3  2 HW200X200X8X12 Q345B   0   0   6.4280E+03 0 0 2.6250E+05 4.6100E+07 1.6010E+07 8.4686E+01 4.9907E+01 4.6100E+05 1.6010E+05 5.0500E+01 2.0000E+02 2.0000E+02 1.2000E+01 8.0000E+00 0 0.000 5.1320E+05 2.4280E+05 1.4140E+11 2
    S   3  2 HW250X250X9X14 Q345B   0   0   9.2180E+03 0 0 5.1470E+05 1.0580E+08 3.6470E+07 1.0713E+02 6.2900E+01 8.4630E+05 2.9180E+05 7.2400E+01 2.5000E+02 2.5000E+02 1.4000E+01 9.0000E+00 0 0.000 9.3690E+05 4.4200E+05 5.0760E+11 2
    S   3  2 HW300X300X10X15 Q345B   0   0   1.2040E+04 0 0 7.7000E+05 1.9930E+08 6.7520E+07 1.2866E+02 7.4886E+01 1.3290E+06 4.5020E+05 9.4500E+01 3.0000E+02 3.0000E+02 1.5000E+01 1.0000E+01 0 0.000 1.4650E+06 6.8180E+05 1.3710E+12 2
    S   3  2 HW350X350X12X19 Q345B   0   0   1.7390E+04 0 0 1.7910E+06 3.9510E+08 1.3580E+08 1.5073E+02 8.8369E+01 2.2570E+06 7.7610E+05 1.3700E+02 3.5000E+02 3.5000E+02 1.9000E+01 1.2000E+01 0 0.000 2.4930E+06 1.1750E+06 3.7190E+12 2
    S   3  2 HW400X400X13X21 Q345B   0   0   2.1950E+04 0 0 2.7470E+06 6.5360E+08 2.2410E+08 1.7256E+02 1.0104E+02 3.2680E+06 1.1200E+06 1.7200E+02 4.0000E+02 4.0000E+02 2.1000E+01 1.3000E+01 0 0.000 3.6000E+06 1.6950E+06 8.0440E+12 2
    D   4 'Welded H sections'
    S   4  2 H300X300X10X16 Q345B   0   0   1.2300E+04 0 0 9.1390E+05 2.0980E+08 7.2020E+07 1.3060E+02 7.6520E+01 1.3990E+06 4.8010E+05 9.6400E+01 3.0000E+02 3.0000E+02 1.6000E+01 1.0000E+01 0 0.000 1.5430E+06 7.2670E+05 1.4520E+12 5
    S   4  2 H350X350X10X16 Q345B   0   0   1.4400E+04 0 0 1.0670E+06 3.3940E+08 1.1440E+08 1.5352E+02 8.9132E+01 1.9390E+06 6.5350E+05 1.1300E+02 3.5000E+02 3.5000E+02 1.6000E+01 1.0000E+01 0 0.000 2.1230E+06 9.8800E+05 3.1890E+12 5
    S   4  2 H500X500X20X20 Q345B   0   0   2.9200E+04 0 0 3.9470E+06 1.3150E+09 4.1700E+08 2.1221E+02 1.1950E+02 5.2600E+06 1.6680E+06 2.2800E+02 5.0000E+02 5.0000E+02 2.0000E+01 2.0000E+01 0 0.000 5.8580E+06 2.5460E+06 2.4000E+13 5
    S   4  2 H500X500X20X25 Q345B   0   0   3.4000E+04 0 0 6.4750E+06 1.5630E+09 5.2110E+08 2.1441E+02 1.2380E+02 6.2530E+06 2.0850E+06 2.6500E+02 5.0000E+02 5.0000E+02 2.5000E+01 2.0000E+01 0 0.000 6.9500E+06 3.1700E+06 2.9380E+13 5
    S   4  2 H500X500X20X28 Q345B   0   0   3.6900E+04 0 0 8.5760E+06 1.7070E+09 5.8360E+08 2.1508E+02 1.2576E+02 6.8290E+06 2.3350E+06 2.8800E+02 5.0000E+02 5.0000E+02 2.8000E+01 2.0000E+01 0 0.000 7.5940E+06 3.5440E+06 3.2490E+13 5
    S   4  2 H500X500X25X32 Q345B   0   0   4.2900E+04 0 0 1.3360E+07 1.9280E+09 6.6720E+08 2.1199E+02 1.2471E+02 7.7100E+06 2.6690E+06 3.3500E+02 5.0000E+02 5.0000E+02 3.2000E+01 2.5000E+01 0 0.000 8.6760E+06 4.0680E+06 3.6500E+13 5
    S   4  2 H500X500X32X36 Q345B   0   0   4.9700E+04 0 0 2.0620E+07 2.1510E+09 7.5120E+08 2.0804E+02 1.2294E+02 8.6030E+06 3.0050E+06 3.8800E+02 5.0000E+02 5.0000E+02 3.6000E+01 3.2000E+01 0 0.000 9.8170E+06 4.6100E+06 4.0370E+13 5
    S   4  2 H700X300X12X30 Q345B   0   0   2.5700E+04 0 0 5.7860E+06 2.2840E+09 1.3510E+08 2.9811E+02 7.2504E+01 6.5240E+06 9.0060E+05 2.0200E+02 7.0000E+02 3.0000E+02 3.0000E+01 1.2000E+01 0 0.000 7.2590E+06 1.3730E+06 1.5150E+13 5
    S   4  2 H800X300X10X28 Q345B   0   0   2.4200E+04 0 0 4.6480E+06 2.8470E+09 1.2610E+08 3.4299E+02 7.2185E+01 7.1190E+06 8.4040E+05 1.8900E+02 8.0000E+02 3.0000E+02 2.8000E+01 1.0000E+01 0 0.000 7.8690E+06 1.2790E+06 1.8770E+13 5
    S   4  2 H800X300X12X30 Q345B   0   0   2.6900E+04 0 0 5.8440E+06 3.0750E+09 1.3510E+08 3.3810E+02 7.0868E+01 7.6870E+06 9.0070E+05 2.1100E+02 8.0000E+02 3.0000E+02 3.0000E+01 1.2000E+01 0 0.000 8.5730E+06 1.3770E+06 2.0010E+13 5
    S   4  2 H900X350X16X32 Q345B   0   0   3.4100E+04 0 0 8.8310E+06 5.0000E+09 2.2900E+08 3.8292E+02 8.1948E+01 1.1110E+07 1.3080E+06 2.6800E+02 9.0000E+02 3.5000E+02 3.2000E+01 1.6000E+01 0 0.000 1.2520E+07 2.0140E+06 4.3070E+13 5
    S   4  2 H1000X400X16X32 Q345B   0   0   4.0600E+04 0 0 1.0060E+07 7.0930E+09 3.4170E+08 4.1798E+02 9.1740E+01 1.4190E+07 1.7080E+06 3.1700E+02 1.0000E+03 4.0000E+02 3.2000E+01 1.6000E+01 0 0.000 1.5890E+07 2.6200E+06 7.9960E+13 5
    S   4  2 H1200X400X16X32 Q345B   0   0   4.3800E+04 0 0 1.0330E+07 1.0690E+10 3.4170E+08 4.9403E+02 8.8325E+01 1.7810E+07 1.7090E+06 3.4200E+02 1.2000E+03 4.0000E+02 3.2000E+01 1.6000E+01 0 0.000 2.0110E+07 2.6330E+06 1.1640E+14 5
    D   5 'Parallel Flange Channels produced in China to GB/T 706'
    S   5  7 150PFC Q235B   0   0   2.2500E+03 0 0 5.4900E+04 8.3400E+06 1.2900E+06 6.0882E+01 2.3944E+01 1.1100E+05 2.5700E+04 1.7700E+01 1.5000E+02 7.5000E+01 9.5000E+00 6.0000E+00 1.0000E+01 0.000 1.2900E+05 4.6000E+04 4.5900E+09 2.4900E+01 0   0.000 5
    S   5  7 180PFC Q235B   0   0   2.6600E+03 0 0 8.1400E+04 1.4100E+07 1.5100E+06 7.2806E+01 2.3826E+01 1.5700E+05 2.9900E+04 2.0900E+01 1.8000E+02 7.5000E+01 1.1000E+01 6.0000E+00 1.2000E+01 0.000 1.8200E+05 5.3800E+04 7.8200E+09 2.4500E+01 0   0.000 5
    S   5  7 200PFC Q235B   0   0   2.9200E+03 0 0 1.0100E+05 1.9100E+07 1.6500E+06 8.0877E+01 2.3771E+01 1.9100E+05 3.2700E+04 2.2900E+01 2.0000E+02 7.5000E+01 1.2000E+01 6.0000E+00 1.2000E+01 0.000 2.2100E+05 5.8900E+04 1.0600E+10 2.4400E+01 0   0.000 5
    S   5  7 230PFC Q235B   0   0   3.2000E+03 0 0 1.0800E+05 2.6800E+07 1.7600E+06 9.1515E+01 2.3452E+01 2.3300E+05 3.3600E+04 2.5100E+01 2.3000E+02 7.5000E+01 1.2000E+01 6.5000E+00 1.2000E+01 0.000 2.7100E+05 6.1000E+04 1.5000E+10 2.2600E+01 0   0.000 5
    S   5  7 250PFC Q235B   0   0   4.5200E+03 0 0 2.3800E+05 4.5100E+07 3.6400E+06 9.9889E+01 2.8378E+01 3.6100E+05 5.9300E+04 3.5500E+01 2.5000E+02 9.0000E+01 1.5000E+01 8.0000E+00 1.2000E+01 0.000 4.2100E+05 1.0700E+05 3.5900E+10 2.8600E+01 0   0.000 5
    S   5  7 300PFC Q235B   0   0   5.1100E+03 0 0 2.9000E+05 7.2400E+07 4.0400E+06 1.1903E+02 2.8118E+01 4.8300E+05 6.4400E+04 4.0100E+01 3.0000E+02 9.0000E+01 1.6000E+01 8.0000E+00 1.4000E+01 0.000 5.6400E+05 1.1700E+05 5.8200E+10 2.7200E+01 0   0.000 5
    S   5  7 380PFC Q235B   0   0   7.0300E+03 0 0 4.7200E+05 1.5200E+08 6.4800E+06 1.4704E+02 3.0361E+01 7.9800E+05 8.9400E+04 5.5200E+01 3.8000E+02 1.0000E+02 1.7500E+01 1.0000E+01 1.4000E+01 0.000 9.4600E+05 1.6100E+05 1.5100E+11 2.7500E+01 0   0.000 5
    D   6 'Hot-rolled equal angles to GB/T 706'
    S   6  10 L50X5 Q235B   0   0   4.8030E+02 0 0 3.9583E+03 1.1270E+05 1.1270E+05 1.5318E+01 1.5318E+01 3.1609E+03 3.1609E+03 3.8000E+00 5.0000E+01 5.0000E+01 5.0000E+00 0 0 1.4340E+01 1.4340E+01 5.5000E+00 0 0 0    0.00 0 0 9.7970E+00 1.0000E+00 2
    S   6  10 L63X5 Q235B   0   0   6.1430E+02 0 0 5.0417E+03 2.3200E+05 2.3200E+05 1.9434E+01 1.9434E+01 5.1097E+03 5.1097E+03 4.8000E+00 6.3000E+01 6.3000E+01 5.0000E+00 0 0 1.7600E+01 1.7600E+01 7.0000E+00 0 0 0    0.00 0 0 1.2373E+01 1.0000E+00 2
    S   6  10 L63X6 Q235B   0   0   7.2880E+02 0 0 8.6400E+03 2.7230E+05 2.7230E+05 1.9329E+01 1.9329E+01 6.0465E+03 6.0465E+03 5.7000E+00 6.3000E+01 6.3000E+01 6.0000E+00 0 0 1.7960E+01 1.7960E+01 7.0000E+00 0 0 0    0.00 0 0 1.2347E+01 1.0000E+00 2
    S   6  10 L70X6 Q235B   0   0   8.1600E+02 0 0 9.6480E+03 3.7850E+05 3.7850E+05 2.1537E+01 2.1537E+01 7.5272E+03 7.5272E+03 6.4000E+00 7.0000E+01 7.0000E+01 6.0000E+00 0 0 1.9720E+01 1.9720E+01 8.0000E+00 0 0 0    0.00 0 0 1.3729E+01 1.0000E+00 2
    S   6  10 L70X8 Q235B   0   0   1.0667E+03 0 0 2.2530E+04 4.8540E+05 4.8540E+05 2.1332E+01 2.1332E+01 9.7951E+03 9.7951E+03 8.4000E+00 7.0000E+01 7.0000E+01 8.0000E+00 0 0 2.0440E+01 2.0440E+01 8.0000E+00 0 0 0    0.00 0 0 1.3696E+01 1.0000E+00 2
    S   6  10 L75X6 Q235B   0   0   8.7970E+02 0 0 1.0370E+04 4.6930E+05 4.6930E+05 2.3097E+01 2.3097E+01 8.6850E+03 8.6850E+03 6.9000E+00 7.5000E+01 7.5000E+01 6.0000E+00 0 0 2.0970E+01 2.0970E+01 9.0000E+00 0 0 0    0.00 0 0 1.4708E+01 1.0000E+00 2
    S   6  10 L75X8 Q235B   0   0   1.1503E+03 0 0 2.4230E+04 6.0320E+05 6.0320E+05 2.2899E+01 2.2899E+01 1.1320E+04 1.1320E+04 9.0000E+00 7.5000E+01 7.5000E+01 8.0000E+00 0 0 2.1690E+01 2.1690E+01 9.0000E+00 0 0 0    0.00 0 0 1.4668E+01 1.0000E+00 2
    S   6  10 L75X10 Q235B   0   0   1.4126E+03 0 0 4.6670E+04 7.2810E+05 7.2810E+05 2.2703E+01 2.2703E+01 1.3850E+04 1.3850E+04 1.1100E+01 7.5000E+01 7.5000E+01 1.0000E+01 0 0 2.2410E+01 2.2410E+01 9.0000E+00 0 0 0    0.00 0 0 1.4663E+01 1.0000E+00 2
    S   6  10 L90X8 Q235B   0   0   1.3944E+03 0 0 2.9350E+04 1.0680E+06 1.0680E+06 2.7675E+01 2.7675E+01 1.6540E+04 1.6540E+04 1.0900E+01 9.0000E+01 9.0000E+01 8.0000E+00 0 0 2.5450E+01 2.5450E+01 1.0000E+01 0 0 0    0.00 0 0 1.7654E+01 1.0000E+00 2
    S   6  10 L90X10 Q235B   0   0   1.7167E+03 0 0 5.6670E+04 1.2950E+06 1.2950E+06 2.7466E+01 2.7466E+01 2.0290E+04 2.0290E+04 1.3500E+01 9.0000E+01 9.0000E+01 1.0000E+01 0 0 2.6180E+01 2.6180E+01 1.0000E+01 0 0 0    0.00 0 0 1.7617E+01 1.0000E+00 2
    S   6  10 L100X8 Q235B   0   0   1.5638E+03 0 0 3.2770E+04 1.4830E+06 1.4830E+06 3.0795E+01 3.0795E+01 2.0590E+04 2.0590E+04 1.2300E+01 1.0000E+02 1.0000E+02 8.0000E+00 0 0 2.7960E+01 2.7960E+01 1.2000E+01 0 0 0    0.00 0 0 1.9611E+01 1.0000E+00 2
    S   6  10 L100X10 Q235B   0   0   1.9261E+03 0 0 6.3330E+04 1.8030E+06 1.8030E+06 3.0596E+01 3.0596E+01 2.5290E+04 2.5290E+04 1.5100E+01 1.0000E+02 1.0000E+02 1.0000E+01 0 0 2.8680E+01 2.8680E+01 1.2000E+01 0 0 0    0.00 0 0 1.9569E+01 1.0000E+00 2
    S   6  10 L100X12 Q235B   0   0   2.2800E+03 0 0 1.0830E+05 2.1070E+06 2.1070E+06 3.0399E+01 3.0399E+01 2.9850E+04 2.9850E+04 1.7900E+01 1.0000E+02 1.0000E+02 1.2000E+01 0 0 2.9400E+01 2.9400E+01 1.2000E+01 0 0 0    0.00 0 0 1.9549E+01 1.0000E+00 2
    S   6  10 L125X8 Q235B   0   0   1.9750E+03 0 0 4.1300E+04 2.9630E+06 2.9630E+06 3.8733E+01 3.8733E+01 3.2640E+04 3.2640E+04 1.5500E+01 1.2500E+02 1.2500E+02 8.0000E+00 0 0 3.4220E+01 3.4220E+01 1.4000E+01 0 0 0    0.00 0 0 2.4598E+01 1.0000E+00 2
    S   6  10 L125X10 Q235B   0   0   2.4373E+03 0 0 8.0000E+04 3.6210E+06 3.6210E+06 3.8544E+01 3.8544E+01 4.0210E+04 4.0210E+04 1.9100E+01 1.2500E+02 1.2500E+02 1.0000E+01 0 0 3.4950E+01 3.4950E+01 1.4000E+01 0 0 0    0.00 0 0 2.4542E+01 1.0000E+00 2
    S   6  10 L125X12 Q235B   0   0   2.8912E+03 0 0 1.3710E+05 4.2500E+06 4.2500E+06 3.8340E+01 3.8340E+01 4.7580E+04 4.7580E+04 2.2700E+01 1.2500E+02 1.2500E+02 1.2000E+01 0 0 3.5670E+01 3.5670E+01 1.4000E+01 0 0 0    0.00 0 0 2.4497E+01 1.0000E+00 2
    S   6  10 L140X10 Q235B   0   0   2.7373E+03 0 0 9.0000E+04 5.1490E+06 5.1490E+06 4.3371E+01 4.3371E+01 5.0830E+04 5.0830E+04 2.1500E+01 1.4000E+02 1.4000E+02 1.0000E+01 0 0 3.8700E+01 3.8700E+01 1.4000E+01 0 0 0    0.00 0 0 2.7579E+01 1.0000E+00 2
    S   6  10 L140X12 Q235B   0   0   3.2512E+03 0 0 1.5440E+05 6.0560E+06 6.0560E+06 4.3159E+01 4.3159E+01 6.0220E+04 6.0220E+04 2.5500E+01 1.4000E+02 1.4000E+02 1.2000E+01 0 0 3.9430E+01 3.9430E+01 1.4000E+01 0 0 0    0.00 0 0 2.7513E+01 1.0000E+00 2
    S   6  10 L160X10 Q235B   0   0   3.1502E+03 0 0 1.0330E+05 7.7840E+06 7.7840E+06 4.9709E+01 4.9709E+01 6.6940E+04 6.6940E+04 2.4700E+01 1.6000E+02 1.6000E+02 1.0000E+01 0 0 4.3710E+01 4.3710E+01 1.6000E+01 0 0 0    0.00 0 0 3.1567E+01 1.0000E+00 2
    S   6  10 L160X12 Q235B   0   0   3.7441E+03 0 0 1.7740E+05 9.1760E+06 9.1760E+06 4.9505E+01 4.9505E+01 7.9410E+04 7.9410E+04 2.9400E+01 1.6000E+02 1.6000E+02 1.2000E+01 0 0 4.4440E+01 4.4440E+01 1.6000E+01 0 0 0    0.00 0 0 3.1500E+01 1.0000E+00 2
    S   6  10 L160X16 Q235B   0   0   4.9067E+03 0 0 4.1510E+05 1.1820E+07 1.1820E+07 4.9081E+01 4.9081E+01 1.0360E+05 1.0360E+05 3.8500E+01 1.6000E+02 1.6000E+02 1.6000E+01 0 0 4.5890E+01 4.5890E+01 1.6000E+01 0 0 0    0.00 0 0 3.1388E+01 1.0000E+00 2
    S   6  10 L200X14 Q235B   0   0   5.4642E+03 0 0 3.5310E+05 2.1060E+07 2.1060E+07 6.2082E+01 6.2082E+01 1.4540E+05 1.4540E+05 4.2900E+01 2.0000E+02 2.0000E+02 1.4000E+01 0 0 5.5190E+01 5.5190E+01 1.8000E+01 0 0 0    0.00 0 0 3.9464E+01 1.0000E+00 2
    S   6  10 L200X16 Q235B   0   0   6.2013E+03 0 0 5.2430E+05 2.3730E+07 2.3730E+07 6.1860E+01 6.1860E+01 1.6470E+05 1.6470E+05 4.8700E+01 2.0000E+02 2.0000E+02 1.6000E+01 0 0 5.5920E+01 5.5920E+01 1.8000E+01 0 0 0    0.00 0 0 3.9393E+01 1.0000E+00 2
    S   6  10 L200X18 Q235B   0   0   6.9301E+03 0 0 7.4260E+05 2.6330E+07 2.6330E+07 6.1639E+01 6.1639E+01 1.8360E+05 1.8360E+05 5.4400E+01 2.0000E+02 2.0000E+02 1.8000E+01 0 0 5.6640E+01 5.6640E+01 1.8000E+01 0 0 0    0.00 0 0 3.9330E+01 1.0000E+00 2
    S   6  10 L200X20 Q235B   0   0   7.6505E+03 0 0 1.0130E+06 2.8850E+07 2.8850E+07 6.1408E+01 6.1408E+01 2.0230E+05 2.0230E+05 6.0100E+01 2.0000E+02 2.0000E+02 2.0000E+01 0 0 5.7370E+01 5.7370E+01 1.8000E+01 0 0 0    0.00 0 0 3.9273E+01 1.0000E+00 2
    D   7 'Hot-rolled unequal angles to GB/T 706'
    S   7  10 L75X50X8 Q235B   0   0   9.4670E+02 0 0 1.9970E+04 5.2610E+05 1.8860E+05 2.3574E+01 1.4114E+01 1.0620E+04 5.0930E+03 7.4000E+00 7.5000E+01 5.0000E+01 8.0000E+00 0 0 2.5470E+01 1.2970E+01 8.0000E+00 0 0 0    0.00 0 0 1.0794E+01 4.3377E-01 2
    S   7  10 L100X80X8 Q235B   0   0   1.3944E+03 0 0 2.9350E+04 1.3800E+06 7.9030E+05 3.1459E+01 2.3807E+01 1.9920E+04 1.3340E+04 1.0900E+01 1.0000E+02 8.0000E+01 8.0000E+00 0 0 3.0740E+01 2.0740E+01 1.0000E+01 0 0 0    0.00 0 0 1.6979E+01 6.3022E-01 2
    S   7  10 L125X80X8 Q235B   0   0   1.5989E+03 0 0 3.3620E+04 2.5570E+06 8.4030E+05 3.9990E+01 2.2925E+01 3.0490E+04 1.3690E+04 1.2600E+01 1.2500E+02 8.0000E+01 8.0000E+00 0 0 4.1120E+01 1.8620E+01 1.1000E+01 0 0 0    0.00 0 0 1.7452E+01 4.1319E-01 2
    S   7  10 L125X80X10 Q235B   0   0   1.9712E+03 0 0 6.5000E+04 3.1200E+06 1.0180E+06 3.9784E+01 2.2725E+01 3.7530E+04 1.6780E+04 1.5500E+01 1.2500E+02 8.0000E+01 1.0000E+01 0 0 4.1860E+01 1.9360E+01 1.1000E+01 0 0 0    0.00 0 0 1.7382E+01 4.0870E-01 2
    S   7  10 L140X90X8 Q235B   0   0   1.8038E+03 0 0 3.7890E+04 3.6360E+06 1.2130E+06 4.4897E+01 2.5932E+01 3.8530E+04 1.7480E+04 1.4200E+01 1.4000E+02 9.0000E+01 8.0000E+00 0 0 4.5620E+01 2.0620E+01 1.2000E+01 0 0 0    0.00 0 0 1.9681E+01 4.1831E-01 2
    S   7  10 L140X90X10 Q235B   0   0   2.2261E+03 0 0 7.3330E+04 4.4480E+06 1.4730E+06 4.4700E+01 2.5723E+01 4.7500E+04 2.1450E+04 1.7500E+01 1.4000E+02 9.0000E+01 1.0000E+01 0 0 4.6360E+01 2.1360E+01 1.2000E+01 0 0 0    0.00 0 0 1.9601E+01 4.1462E-01 2
    S   7  10 L140X90X12 Q235B   0   0   2.6400E+03 0 0 1.2560E+05 5.2240E+06 1.7190E+06 4.4484E+01 2.5517E+01 5.6240E+04 2.5310E+04 2.0700E+01 1.4000E+02 9.0000E+01 1.2000E+01 0 0 4.7100E+01 2.2100E+01 1.2000E+01 0 0 0    0.00 0 0 1.9540E+01 4.1054E-01 2
    S   7  10 L160X100X10 Q235B   0   0   2.5315E+03 0 0 8.3330E+04 6.6640E+06 2.0640E+06 5.1307E+01 2.8554E+01 6.2280E+04 2.6810E+04 1.9900E+01 1.6000E+02 1.0000E+02 1.0000E+01 0 0 5.3000E+01 2.3000E+01 1.3000E+01 0 0 0    0.00 0 0 2.1854E+01 3.9593E-01 2
    S   7  10 L160X100X12 Q235B   0   0   3.0054E+03 0 0 1.4280E+05 7.8460E+06 2.4150E+06 5.1094E+01 2.8347E+01 7.3840E+04 3.1660E+04 2.3600E+01 1.6000E+02 1.0000E+02 1.2000E+01 0 0 5.3740E+01 2.3740E+01 1.3000E+01 0 0 0    0.00 0 0 2.1775E+01 3.9250E-01 2
    D   8 'Cold formed square hollow sections to GB/T 6728'
    S   8  4 F80X5 Q345B   0   0   1.4356E+03 0 0 2.1090E+06 1.4130E+06 1.4130E+06 3.1373E+01 3.1373E+01 3.5310E+04 3.5310E+04 1.1300E+01 8.0000E+01 8.0000E+01 5.0000E+00 4.2250E+04 4.2250E+04 3
    S   8  4 F100X6 Q345B   0   0   2.1632E+03 0 0 4.9840E+06 3.3360E+06 3.3360E+06 3.9270E+01 3.9270E+01 6.6720E+04 6.6720E+04 1.7000E+01 1.0000E+02 1.0000E+02 6.0000E+00 7.9630E+04 7.9630E+04 3
    S   8  4 F120X8 Q345B   0   0   3.4191E+03 0 0 1.1240E+07 7.5310E+06 7.5310E+06 4.6932E+01 4.6932E+01 1.2550E+05 1.2550E+05 2.6800E+01 1.2000E+02 1.2000E+02 8.0000E+00 1.5080E+05 1.5080E+05 3
    S   8  4 F130X8 Q345B   0   0   3.6842E+03 0 0 1.4530E+07 9.7260E+06 9.7260E+06 5.1380E+01 5.1380E+01 1.4960E+05 1.4960E+05 2.8900E+01 1.3000E+02 1.3000E+02 8.0000E+00 1.7890E+05 1.7890E+05 3
    S   8  4 F150X8 Q345B   0   0   4.3242E+03 0 0 2.2910E+07 1.5320E+07 1.5320E+07 5.9522E+01 5.9522E+01 2.0430E+05 2.0430E+05 3.3900E+01 1.5000E+02 1.5000E+02 8.0000E+00 2.4220E+05 2.4220E+05 3
    S   8  4 F200X10 Q345B   0   0   7.2600E+03 0 0 6.8590E+07 4.5850E+07 4.5850E+07 7.9470E+01 7.9470E+01 4.5850E+05 4.5850E+05 5.7000E+01 2.0000E+02 2.0000E+02 1.0000E+01 5.4200E+05 5.4200E+05 3
    D   9 'Cold formed rectangular hollow sections to GB/T 6728'
    S   9  4 J100X50X5 Q345B   0   0   1.3356E+03 0 0 1.3050E+06 1.7370E+06 5.6170E+05 3.6063E+01 2.0508E+01 3.4730E+04 2.2470E+04 1.0500E+01 1.0000E+02 5.0000E+01 5.0000E+00 4.4000E+04 2.6500E+04 3
    S   9  4 J120X80X6 Q345B   0   0   2.1632E+03 0 0 4.5430E+06 4.3820E+06 2.2900E+06 4.5008E+01 3.2536E+01 7.3030E+04 5.7250E+04 1.7000E+01 1.2000E+02 8.0000E+01 6.0000E+00 8.9710E+04 6.7150E+04 3
    S   9  4 J140X80X6 Q345B   0   0   2.4032E+03 0 0 5.6730E+06 6.4090E+06 2.6190E+06 5.1642E+01 3.3012E+01 9.1560E+04 6.5480E+04 1.8900E+01 1.4000E+02 8.0000E+01 6.0000E+00 1.1350E+05 7.6030E+04 3
    S   9  4 J150X100X8 Q345B   0   0   3.5791E+03 0 0 1.1670E+07 1.1280E+07 5.8810E+06 5.6139E+01 4.0536E+01 1.5040E+05 1.1760E+05 2.8100E+01 1.5000E+02 1.0000E+02 8.0000E+00 1.8540E+05 1.3860E+05 3
    S   9  4 J160X80X8 Q345B   0   0   3.3644E+03 0 0 8.5550E+06 1.1380E+07 3.6810E+06 5.8159E+01 3.3077E+01 1.4230E+05 9.2020E+04 2.6800E+01 1.6000E+02 8.0000E+01 8.0000E+00 1.8020E+05 1.0850E+05 3
    S   9  4 J200X100X6 Q345B   0   0   3.3632E+03 0 0 1.3860E+07 1.7940E+07 5.9900E+06 7.3036E+01 4.2202E+01 1.7940E+05 1.1980E+05 2.6100E+01 2.0000E+02 1.0000E+02 6.0000E+00 2.2240E+05 1.3600E+05 3
    S   9  4 J200X100X8 Q345B   0   0   4.3791E+03 0 0 1.7580E+07 2.3060E+07 7.5790E+06 7.2567E+01 4.1602E+01 2.3060E+05 1.5160E+05 3.4400E+01 2.0000E+02 1.0000E+02 8.0000E+00 2.8900E+05 1.7540E+05 3
    S   9  4 J250X150X6 Q345B   0   0   4.5600E+03 0 0 3.8180E+07 4.0280E+07 1.8190E+07 9.3986E+01 6.3159E+01 3.2220E+05 2.4250E+05 3.5800E+01 2.5000E+02 1.5000E+02 6.0000E+00 3.8950E+05 2.7310E+05 3
    S   9  4 J250X150X8 Q345B   0   0   5.9200E+03 0 0 4.9200E+07 5.2240E+07 2.3390E+07 9.3938E+01 6.2857E+01 4.1790E+05 3.1190E+05 4.6500E+01 2.5000E+02 1.5000E+02 8.0000E+00 5.0940E+05 3.5580E+05 3
    D   10 'Hot-rolled seamless tubes to GB/T 8162'
    S   10  6 PIP42x4 Q345B   0   0   4.8100E+02 0 1.7840E+05 8.9200E+04 1.3618E+01 4.2181E+03 3.8000E+00 4.2000E+01 4.0000E+00 5.8889E+03 2
    S   10  6 PIP89x6 Q345B   0   0   1.5650E+03 0 2.7090E+06 1.3540E+06 2.9414E+01 3.0430E+04 1.2300E+01 8.9000E+01 6.0000E+00 4.1410E+04 2
    S   10  6 PIP114x6 Q345B   0   0   2.0360E+03 0 5.9550E+06 2.9770E+06 3.8238E+01 5.2230E+04 1.6000E+01 1.1400E+02 6.0000E+00 7.0060E+04 2
    S   10  6 PIP140x5 Q345B   0   0   2.1210E+03 0 9.6750E+06 4.8380E+06 4.7760E+01 6.9110E+04 1.6600E+01 1.4000E+02 5.0000E+00 9.1170E+04 2
    S   10  6 PIP168X6 Q345B   0   0   3.0540E+03 0 2.0060E+07 1.0030E+07 5.7308E+01 1.1940E+05 2.4000E+01 1.6800E+02 6.0000E+00 1.5750E+05 2
    S   10  6 PIP168X8 Q345B   0   0   4.0210E+03 0 2.5800E+07 1.2900E+07 5.6641E+01 1.5360E+05 3.1600E+01 1.6800E+02 8.0000E+00 2.0500E+05 2
    S   10  6 PIP219x8 Q345B   0   0   5.3030E+03 0 5.9110E+07 2.9550E+07 7.4648E+01 2.6990E+05 4.1600E+01 2.1900E+02 8.0000E+00 3.5630E+05 2
    S   10  6 PIP273x8 Q345B   0   0   6.6600E+03 0 1.1700E+08 5.8520E+07 9.3738E+01 4.2870E+05 5.2300E+01 2.7300E+02 8.0000E+00 5.6200E+05 2
    S   10  6 PIP273x10 Q345B   0   0   8.2620E+03 0 1.4310E+08 7.1540E+07 9.3053E+01 5.2410E+05 6.4900E+01 2.7300E+02 1.0000E+01 6.9200E+05 2
    S   10  6 PIP325x8 Q345B   0   0   7.9670E+03 0 2.0030E+08 1.0010E+08 1.1209E+02 6.1620E+05 6.2500E+01 3.2500E+02 8.0000E+00 8.0410E+05 2
    S   10  6 PIP325x10 Q345B   0   0   9.8960E+03 0 2.4570E+08 1.2290E+08 1.1144E+02 7.5610E+05 7.7700E+01 3.2500E+02 1.0000E+01 9.9260E+05 2
    S   10  6 PIP351X8 Q345B   0   0   8.6210E+03 0 2.5370E+08 1.2680E+08 1.2128E+02 7.2280E+05 6.7700E+01 3.5100E+02 8.0000E+00 9.4140E+05 2
    S   10  6 PIP351X10 Q345B   0   0   1.0710E+04 0 3.1170E+08 1.5580E+08 1.2061E+02 8.8800E+05 8.4100E+01 3.5100E+02 1.0000E+01 1.1630E+06 2
    S   10  6 PIP351X12 Q345B   0   0   1.2780E+04 0 3.6760E+08 1.8380E+08 1.1992E+02 1.0470E+06 1.0030E+02 3.5100E+02 1.2000E+01 1.3800E+06 2
    S   10  6 PIP402X10 Q345B   0   0   1.2310E+04 0 4.7340E+08 2.3670E+08 1.3867E+02 1.1780E+06 9.6700E+01 4.0200E+02 1.0000E+01 1.5370E+06 2
    S   10  6 PIP450X10 Q345B   0   0   1.3860E+04 0 6.6940E+08 3.3470E+08 1.5540E+02 1.4880E+06 1.0850E+02 4.5000E+02 1.0000E+01 1.9360E+06 2
    S   10  6 PIP500X10 Q345B   0   0   1.5390E+04 0 9.2440E+08 4.6220E+08 1.7330E+02 1.8490E+06 1.2080E+02 5.0000E+02 1.0000E+01 2.4010E+06 2
    S   10  6 PIP500X12 Q345B   0   0   1.8390E+04 0 1.0960E+09 5.4800E+08 1.7262E+02 2.1920E+06 1.4440E+02 5.0000E+02 1.2000E+01 2.8580E+06 2
    S   10  6 PIP630X10 Q345B   0   0   1.9470E+04 0 1.8720E+09 9.3620E+08 2.1928E+02 2.9720E+06 1.5290E+02 6.3000E+02 1.0000E+01 3.8440E+06 2
    S   10  6 PIP630X13 Q345B   0   0   2.5190E+04 0 2.3990E+09 1.2000E+09 2.1826E+02 3.8080E+06 1.9780E+02 6.3000E+02 1.3000E+01 4.9500E+06 2
    D   11 'Bluescope Lysaght C sections produced in China'
    S   11  45 C20015 G350   0   0   5.5500E+02 0 0 4.1600E+02 3.5300E+06 3.9600E+05 1.5000E+00 2.0300E+02 7.6000E+01 1.8000E+01 5.0000E+00
    S   11  45 C20024 G350   0   0   9.0400E+02 0 0 1.7400E+03 5.6900E+06 6.8100E+05 2.4000E+00 2.0300E+02 7.6000E+01 1.8000E+01 5.0000E+00
    S   11  45 C25024 G350   0   0   1.0200E+03 0 0 1.9700E+03 9.6200E+06 7.2100E+05 2.4000E+00 2.5400E+02 7.6000E+01 2.0000E+01 5.0000E+00
    D   12 'Bluescope Lysaght Z sections produced in China'
    S   12  50 Z20015 G350   0   0   5.5500E+02 0 0 4.1600E+02 3.5300E+06 6.2100E+05 1.5000E+00 2.0300E+02 7.9000E+01 7.4000E+01 1.8000E+01 5.0000E+00
    S   12  50 Z20024 G350   0   0   9.0700E+02 0 0 1.7400E+03 5.7000E+06 1.1000E+06 2.4000E+00 2.0300E+02 7.9000E+01 7.4000E+01 1.8000E+01 5.0000E+00
    S   12  50 Z25024 G350   0   0   1.0300E+03 0 0 1.9700E+03 9.6400E+06 1.0800E+06 2.4000E+00 2.5000E+02 7.8000E+01 7.2000E+01 2.0000E+01 5.0000E+00
    Thank you
  • It's working OK for me. I tested only a shear tab connection.
    I happen to have the International flag on in case that matters.
    And I am using v 3.63.2.7
Reply Children
