Hi
I have updated StaadPro new version yesterday.
In section wizard, there is no import dxf drawing as shown below.
In the previous version, the drawing (dxf) can be imported as per the figure below.
I need to get section properties of the attached profile which I could do in the previous version.
Could you please help to solve this issue?
You should still be able to import a DXF using the Free Sketch tool. Your first screenshot is of the main Section Wizard window, where as your second screenshot is from Free Sketch.
There are limitations on the type of cad entities supported. Please refer to the online help topic for details.
If you want to switch back to the Section Builder interface, select Service > Section Builder.
Jason Coleman, PE
Bentley Systems Senior Manager Technical Content
Answer Verified By: Sye
Appreciate your reply.
Now I understand that I need one more step which is to go to free sketch tool for importing dxf.
Thanks so much!
