Could anyone please guide me on the properties that I should input for semi-rigid diaphragm in RAM Structural system, in the decking properties for the Laminated Lockwood wood deck?
Effective thickness (in) - ______
Poisson's Ratio - ___________
Elastic Modulus (ksi) - _________
Thank You!!
You would have to get those from the manufacturer. Just using the values of some solid sawn lumber is a start.
