Hello, I´m designing two small guardhouses in STAAD.Pro V8i SS5, both are RC structures with slab foundations, they are almost equal in principal geometry, loading and sections, the only thing that changes considerably from one model to the other is the value for the sub-grade modulus which, understandably, does have a noticeable effect in the base pressure summary, aside from that there are some small differences in the distribution of the slab and the secondary frame, but in my opinion these are minor changes that should hardly affect the behavior of the model. The difference in results starts with the reactions in the columns (Beam end forces), for one model the maximum axial force has a value of 11,418.17 kg and for the other one it has a value of 8,857.23 kg, after that I notice that the joint displacements in the beam centers (I´m calculating beam deflection with those values) are also very different with values going from 0.598 cm in one model to 0.266 cm in the other for example, I´m assuming that I´ll be seeing variations along the same lines for drift values and probably also steel reinforcement values. So my question is: What I´m I doing wrong or differently between the two models so that my results change so noticeably or is it normal for them to change like this? The models are attached. If something needs clarification please let me know and I´ll do my best. Thanks in advance for any help.
Caseta de vigilancia Punta de Palmas 21-05-19.stdCaseta de vigilancia Peonías 08-08-19.std
Just a quick suggestion...
Have you tried to use only one model and varying only the subgrade model? I am under the impression that the softer subgrade is allowing the one model settle more which would induce more forces and displacement.
Perhaps, if hold the model constant and vary only the subgrade (sensitivity analysis) this could provide you some insight on how sensitive is the model response when varying the modulus of subgrade.
I tried that, went from a sub-grade modulus of 4.80 kg/cm3 to one of 0.96 kg/cm3, this resulted in a significantly lower value of base pressure (from 1,29 kg/cm2 to 0,53 kg/cm2 aprox.) and a small increase in beam end forces (from 8,857.023 kg to 9,300.00 kg aprox.), however what worries me is the difference in displacements and forces in elements, I also don´t think the design of the superstructure should be greatly affected by the sub-grade modulus, maybe I´m wrong about this last one, especially when we model everything in one single file.
here is an article (of many available on the internet) discussing the influence the modulus of subgrade to the end forces and displacement.
PDF
