Results Along Line
After analysis i need to modify the geometry of one member. If i need this modification i will lose the cut lines created with results along line tool. I'd like to find a way to not lose the cutting lines after making the modify and relaunching the analysis. Is it possible?
I used STAAD.Pro CONNECT V22 packeage1.
Parents Reply Children
