<?xml version="1.0" encoding="UTF-8" ?>
<?xml-stylesheet type="text/xsl" href="https://communities.bentley.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/"><channel><title>slab edges to create a diaphragm in each of the 5 bays</title><link>https://communities.bentley.com/products/ram-staad/f/ram-staad-forum/189057/slab-edges-to-create-a-diaphragm-in-each-of-the-5-bays</link><description>I need to create a separate diaphragm in each of the bays but I am having issues with the slab edge and load distribution. If i align the slab edges along the shared shear wall i get a message that the slab edges are intersecting. If I offset the edges</description><dc:language>en-US</dc:language><generator>Telligent Community 12</generator><item><title>RE: slab edges to create a diaphragm in each of the 5 bays</title><link>https://communities.bentley.com/thread/556380?ContentTypeID=1</link><pubDate>Mon, 25 Nov 2019 17:23:25 GMT</pubDate><guid isPermaLink="false">6dad98f5-dbc9-4c4d-a9ba-e9da8dc6aa8e:01e47701-1d0c-47d4-95e8-40174508c76d</guid><dc:creator>Seth Guthrie</dc:creator><description>&lt;p&gt;In order to model an expansion joint separating diaphragms in RAM SS, the slab edges need to be non-intersecting. For one way deck systems, this generally means that two parallel lines of beams or walls with parallel slab edges and a small gap (at least 1&amp;quot;) is required. Maybe this exercise could be accomplished more easily with one all-encompassing slab edge and then just making the diaphragm flexible.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
