Could you please let me know the reason for difference between these values?
For masses we typically split the height of the story above and below the diaphragm, but for notional loads it's the full height below. Check via Ram Manager - Criteria - Self-weight. See also: https://communities.bentley.com/products/ram-staad/w/structural_analysis_and_design__wiki/17968/ram-frame---masses
