RAM Elements - Masonry Wall Module
I am designing Masonry SWs in RAM Elements for the first time. I imported the RSS Lateral model into Elements and have been designing each wall after assigning properties, criteria, etc. I have a couple questions about the program and its limitations.
1) From what I can tell, there is no way to add bond beams in the module. I can uncheck joint reinforcement to get the required horizontal reinforcement. Is this a correct assumption? When this option is selected, there is a typo in the detailing of the horiz reinforcing because it still says EF (each face), even tho it is showing (1) bar. I am planning on resolving the required horiz reinf into an equivalent bond beam spacing.
 2) When I model the wall openings in RAM, I cannot get any reasonable design to work for openings near wall ends. Even though I have modeled my walls as connected (i.e. stairwells, elevator cores), it seems RAM Elements does not allow you to consider the corners with the perpendicular walls for additional capacity. What do you recommend for these conditions?
Parents Reply Children
