Why does RAM Structural System round down the Yield Strength fy value? I am located in Canada so if I use american steel then I convert the fy=50 000psi to MPa which is approximately 345MPa. So in the Modeler when laying out the beams I type in 345MPa, then in the Beam Design -> View/Update Beam it says Fy (N/mm2): 345, but when I go to View Results for a closer look it says Grade = 300W (corresponding Design fy=300MPa)?Now if I use 350MPa it uses the proper yield strength so to me it appears as though there are thresholds which it automatically rounds down to if crossed.
For more on this see: https://communities.bentley.com/products/ram-staad/w/structural_analysis_and_design__wiki/13884/ram-ss-design-fy-or-py
Answer Verified By: Dmitri Babisin
